How can I create and sample and hold circuit in Labview?
Henrik, THIS is the one I meant to reply to.  I'm not sure what I did wrong.  I need it to be Friday though.  My brain usually doesn't shut down this early in the week!
Message 11 of 12
(372 Views)
Oh.. after looking at my old code ....
So, I made some simplifications of a multiplexed input.
You define a samplerate SR, now for each channel 12 more 'subsamples' are calculated (so the simulation has a samplerate SR*12*<No of channels>)
during one nominal SR duration all channels are succesiv sampled , beginning with a switch delay (switch charge ingnored) of one subsample, 10 subsample while the capacitor of the S&H is charged from its current state to the value actual channel value following a RC time constant. The C is the C from the S&H and the R is build by the MUX resistance and the output impedance of the source. (all the same in my sim.. still room for improvements ;), so I simply used one RC timeconstant for all channels) , during the last remaining subsample the value stored.
So one can see the settletime error and crosstalk due to the remaining charge in S&H capacitor  and the source impedance   and the different phase delays of the channels due to the muxing
Greetings from Germany
Henrik
LV since v3.1
Message 12 of 12
(322 Views)
