How can I create and sample and hold circuit in Labview?
I am trying to find a simple way to create a sample and hold circuit in Labview for analog to digital conversion. Any suggestions are appreciated!
Message 1 of 12
(9,744 Views)
Can you explain more learly what you are trying to do?
LabVIEW is a program which runs on digital computers.  It operates on digital values.
If you want to convert some continuous voltage signal to a digital representation, you need some kind of hardware - an electronic circuit - to do that conversion.  NI offers a wide variety of A/D conversion devices, software drivers for them, and LabVIEW to control all of those.
Lynn
Message 2 of 12
(9,718 Views)
I am generating a continuous sinusoid with the waveform generator in Labview. I want to simulate a sample and hold circuit, not actually use separate hardware.
Message 3 of 12
(9,694 Views)
Accepted by topic author westerman111
How about something like this??
Message 4 of 12
(9,683 Views)
You can do the same without any local variables... 😉
Message 5 of 12
(9,670 Views)
Hmm .....no local variables?
Give me a hint! Smiley Happy
Message 6 of 12
(9,648 Views)
Shift Register.
Also both cases of the case structure do the same thing with the boolean:  (Flip its state.)  That is a Not function and it is moved outside of the case stucture.
(Note, the boolean wire through the case structure may not be necessary.  It all depends on whether you want the indicator to change appearance after the sample value is shown.  In real life, this would appear to be simultaneous and shouldn't matter.  But wiring it through effectively makes the VI behave more like what you have coded up.)
Message 7 of 12
(9,556 Views)
Out of curiosity and for educational reasons I build a simple Sample & Hold simulation for a multiplexed input including the effect of crosstalk due to the S&H cap.
Crosstalk can be seen in the pic on the dark blue Out 4 plot  🙂  and the per channel group delay ...
I was to lasy to add the bit resolution digitizer ....
Have fun 😄
Greetings from Germany
Henrik
LV since v3.1
Message 8 of 12
(9,529 Views)
Henrik, I apologize.  I wasn't even thinking when I PM'd you that you wouldn't receive a link to the VI I was referencing.   But, I've copied the PM here and I hope it finds you well.  I've been studying your S&H simulation with MUX and crosstalk.  Beautiful work!  I hate to ask and expose my pitiful working knowledge of LabVIEW as compared to yours, but I cannot for the life of me fisure out how to take your example and "dumb it down" to just one sine wave and its associated sample and hold representation.  The multiplexing and sample cap has me stumped.  I know I can either just set the front panel No. Channels control to 1 and/or turn off the Plot Visible option for all except 2 of the traces, but I'm trying to understand what it actually is that you're doing with the multiplexing and the crosstalk. Would you be willing to help improve my knowledge of the subject, or point me in the right direction.
Message 9 of 12
(1,081 Views)
However, doesn't seems to be the right thread 😉
Henrik
LV since v3.1
Message 10 of 12
(1,061 Views)
