How can I design this subVI's connector?
I have one input and 16 outputs in my sub-vi.
how can I design the connector.in the connector's Patterns,there is 16 terminal.
(3,073 Views)
If you right-click on the VI's icon in the top right corner and select patterns you can select a connector pattern that has more terminals. The maximum is 28.
If you ever need more than 28 the solution is to use clusters and arrays.
(3,073 Views)
but there are not 17 terminal in the patterns
(3,073 Views)
You do not need to use them all, just select a pattern that has more than 17 and wire up the ones you need.
(3,073 Views)
You can also adapt it exactly to the number of terminals you need; if you have 16 and just want one extra just right-click on the pattern (where you assign terminals) and choose to add a terminal.
(3,073 Views)
hi cws....
what do you think about the solution attached ???
with only one output !!!!
this is much easier to handle especially if you need
this as sub.vi
regards
Werner
(3,073 Views)
think you very much!
I see .
(3,073 Views)
