How can I detect system hang up?
Hello
I am providing only my LV project exe as custom shell with Windows Embedded standard 7 operating system.
If my LV program hangs up by chance, then I want to provide option which should automatically detect the system hang up and reset at that point automatically.
I have come to know that it is possible by Watchdog API.
But I don't have the solution.
Please help me if anybody have any idea about this issue.
Thank you in Advance!!!!!
(2,551 Views)
I've done something like that a while ago :
In addition to what i had to do, the application was configured to send pulses at a 1Hz rate to an external device (I had a spare digital output line on a Daq board but I don't remember what board it was).
The external device (separate from the PC on wich the application runs) would "cut" the PC's power cable for a second to force the OS (windows 2000 at the time) to restart. The application was set to be started when windows starts.
I haven't had to do this for long long time, maybe you have that integrated in some way with a watchdog API...
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,541 Views)
