How to increase number by every n'th iteration in loop
Hi
I am trying to build a 1D array of strings containing numbers where the value inserted into the array is increased by n'th step.
E.g. the length of the array can be arbitrary, let's say an array length of 107. The values I want to fill the array with starts from "1" (including " ", therefore a string), and for each 10th iteration the value is is increase by +1.
The should look something like this then
"1"
"1"
"1"
"2"
"2"
"2"
and so on until an array length of 107 is reached.
I tried something with some for loops, but i can't seem to get it to work.
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
(5,551 Views)
Hey,
Try this.. you may have to insert different string functions to isolate the number if you're string is anything more then just a number.
- Rkll
(5,544 Views)
22651iAE6BEE2E93E941CE
Felix
(5,528 Views)
Accepted by topic author Little_Helper
Why make things complicated.
Add a number to string as needed.
22655i7956797129AC0165
/Y
Qestit Systems
Certified-LabVIEW-Developer
(5,522 Views)
That is very neat. I just added a concatenate string to add " before and after the number, which solved my problem.
Thank you very much.
VBAI 3.6 / 2010
(5,511 Views)
I was searching like this vi. I played a little bit on it but exactly what I need. Thanks alot.
(5,248 Views)
