How can I display an image with a fixed display flickering rate?
Thank you very much. You really helped me.
Message 11 of 12
(323 Views)
While many displays have 60 Hz refresh rates, other rates are in use. For example Apple does not even define the update rate on iMacs using DisplayPort technology.  Regardless of the rate you will not be able to synchronize exactly with the display unless you want to dig down into the interface signals.
The OS may not always immediately update the screen when new data is sent.
You should plan to do some careful testing and calibration to assure that the you get the display patterns that you want. The simplest test might use a photodiode and an oscilloscope.
Lynn
Message 12 of 12
(318 Views)
