How can I do a bit mask?
How can I do a bit mask in LabVIEW?  For example, what the easiest way to see if bit 3 is set in a 32-bit unsigned int?
(15,812 Views)
AND the U32 with another U32 with the 3rd bit set to 1 (easy to do in binary formatting).
To set a bit, use the OR operator.
Boolean operators work very nice with integer numbers.
Message Edited by dan_u on 03-12-2010 01:06 AM
(15,805 Views)
your int AND 4 (or change visual option of the '4' to binary and write '100')
Then either compare to 0, 4 or >0.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(15,804 Views)
Given: X is the input for bit 3 testing
1. X AND 8 = y (notice that at is 00000000000000000000000000001000 binary in decimal)
2. Convert y to a boolean array = z
3. Or all element in array(z) = result
If result is true, bit 3 is set.  If not, bit 3 is clear.
Yik
Kudos and Accepted as Solution are welcome!
(15,788 Views)
Accepted by garya505
As already said, AND.
Jim
(15,762 Views)
Well explained Jim.
If you do a bit mask and the bit(s) you are looking for is set, then it does not matter what the answer is, it will not be zero.  So result != 0 means the bit was set.  🙂
(15,747 Views)
Thanks to all for the great answers!  My first reading of the LV Help for AND led me to think it was only boolean, not bitwise.
(15,720 Views)
