How can I do a phase shift and amplitude change on wavefile thats read in
Greetings All
I have a wavefile that has two channels Left and Right I would like to do a phase
shift and amplitude change on one of the channels.  I can seperate each channel
into arrays but I'm not sure how to do a phase shift and do an amplitude change on the
array to get the new signal.
tia sal22
(3,199 Views)
here's the Vi I'm referring to..
(3,177 Views)
Accepted by sal22
Hi Sal,
Here's one way to implement the phase shift:
 In terms of amplitude change, you could just multiply the entire array by the value you want.
Message Edited by Smootastic on 08-10-2009 05:51 PM
(3,151 Views)
Thanks that really helped here's the final version in case anyone else may need to do this
(3,139 Views)
