How can I do a start ramp?
I'm trying to do a start ramp in a FPGA Target and i don't know how to do it.
It is for speed motor control.
Somebady can help me?
Message 1 of 12
(6,348 Views)
Hi pablo,
for a ramp you usually have a start value, end value and a given time. You increment your start value with a certain time delay until you reached your end value…
You will need to do the very same on your FPGA!
Message 2 of 12
(6,344 Views)
There is a "Ramp Pattern" VI that will output an array of values based on your start, end and either # of samples or delta change.
aputman
Message 3 of 12
(6,277 Views)
Read more carefully.  We are in the FPGA realm.  That function does not exist there.
Message 4 of 12
(6,262 Views)
My bad.  I am not familiar with FPGA.
aputman
Message 5 of 12
(6,257 Views)
That's my problem. In the FPGA realm i don't know how to do it.
Message 6 of 12
(6,207 Views)
Hi Pablosan,
dy = (endvalue - startvalue)*dt/t
y = startvalue
while y < endvalue
   output(y)
   y := y + dy
   wait(dt)
wend
Looks pretty simple to generate a ramp…
Message 7 of 12
(6,198 Views)
but how can i do with block diagram? i don't understand how to do the timer!
Message 8 of 12
(6,175 Views)
Hi pablosan,
what's the problem with using a wait function? Even the FPGA knows how to wait for a certain amount of time…
Message 9 of 12
(6,169 Views)
I do this, but i don't know how to change de shift register in double to FTP.shift register.jpg
Message 10 of 12
(6,122 Views)
