How can I do that I move a slider and if I it equals 2 then equals 3 then equals 5 turn then on a led?
Message 1 of 12
(3,942 Views)
I am not following what you want.  A slider has many values between your endpoints.  So how exactly are you determining that it was at 2, then 3, and then 5?  You have to change to 4 before you can go to 5.
GCentral
Message 2 of 12
(3,929 Views)
I want to detect the slider movement
Message 3 of 12
(3,926 Views)
Look at the value change event for the slider.
Keep track of the changes within an array in a shift register.  When the pattern matches what you want, then act on it.
But as crossulz's pointed out, the change from 3 to 5 might inherently have a value change to 4 in between.  Does that mess you up?  You may also have to add some code to handle the array and clear things out if the pattern is not what you want.
When do you want the LED to turn off?
Message 4 of 12
(3,915 Views)
Well that is a simple Event Structure using the slider's Value Change event.
GCentral
Message 5 of 12
(3,914 Views)
can you help me how do it? I am very amatuer and i cant do it 😞
Message 6 of 12
(3,882 Views)
There is no shortcut.
LEARN how to program in LabVIEW. http://www.ni.com/academic/students/learn-labview/
Message 7 of 12
(3,873 Views)
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
GCentral
Message 8 of 12
(3,864 Views)
Accepted by elefank
you linked a lot of things what help me nothing because none of them tell me how i can detect my sliders moving but okey ty
Message 9 of 12
(3,858 Views)
We already told you to use an Event Structure.  Those tutorials will teach you to use them.
GCentral
Message 10 of 12
(3,854 Views)
