How can I do the difference of position (X2-X1) and (y2-y1) between two (2) cursor distinct ?
Como posso fazer uma diferença de posição (X2-X1) e (y2-y1) entre dois (2) distintos cursor? Veja uma imagem com o erro: não entendi. Muito obrigado. Juscelino.
(3,417 Views)
Accepted by Juscelino
You could do something like the following.
Message Edited by altenbach on 02-06-2010 10:02 AM
(3,392 Views)
Interestingly, the other thread was marked as solved before this thread got even started, so we have to conclude that the other solution is not correct. 😉
(3,353 Views)
