How can I extract the frequency of a (possibly noisy) signal?
The simplest filter that can be built is a Moving Average Filter (FIR with equal coefficients = 1/N, N=filter order). You have an example in the attachment.
For building other filters you have to:
- search on internet for sites which have applets for filter coefficient computing. You have to choose filter type (IIR, FIR), characteristic (low pass, band pass..) and frequencies (Fc, Fs ..) and you'll get the coefficients
- implement the filter using one (for IIR) or two (for IIR) shift register. A shift register is an array which is shifted after each sample (FIFO).
Paul
Message 11 of 25
(1,714 Views)
Thanks Lynn,
I dont know exactly what you mean by smoothing technique. It would be great if you could give me some example.
Thanks.
Message 12 of 25
(1,707 Views)
Thanks Paul,
Unfortunately I cannot open this file. My labview is 2009.
Message 13 of 25
(1,703 Views)
Now it should work also under 9.0
Message 14 of 25
(1,700 Views)
Yeah. It works.
Thanks Paul.
Message 15 of 25
(1,698 Views)
I am trying to figure out how it works. So what is the cut-off frequency of this filter? and how can I see the output in a graphical indicator (it doesn't give me the option)? I know some of my questions may look primitive, but I am new to labview.
Message 16 of 25
(1,692 Views)
Asking questions is how you learn. We were all new to LV once.
Message 17 of 25
(1,690 Views)
Oh, Thanks. That was encouraging.
Message 18 of 25
(1,687 Views)
Baran,
On this topic you are all by yourself. There is nothing that LabView can help you with filters, especially if you have the the basic version.
For digital filters, the cutting frequency is strong related to the sampling frequency. Using the same filter at different sampling frequency you'll get different cutting frequency. The Moving Average Filter is far away of being the best choice but it's ok, and works for most of the cases where advance signal analyze is not required.
You have to search on internet some Digital Filter basics. Building a Digital Filter is easy, you need to add, multiply some value and to shift some samples.You just need to understand some basics.
You can use the VI as a subvi and to connect to input (Array Input) a Sine + Noise and to add at output a Graph.
Paul
Message 19 of 25
(1,683 Views)
I found out how to have a graphical indicator, just replaced it in front panel. But I am still wondering why in block diagram it doesn't give me the option to have a graphical indicator!
anyway, thanks. I guess I got it now. just one last thing. You said I can use it as subVI in other VIs. Is it a way I can group them together and save them for future use (like functions), or I just can copy/paste them anytime I need to use.
Thanks again.
Message 20 of 25
(1,674 Views)
