How can I find the frequency of a signal from a turbine flowmeter?
My turbine flow meters output a voltage signal frequency. Is there are way that I can find the frequency in LabVIEW? Right now I have the flow meters wired to my card as analog inputs. Maybe I need to wire them in differently.
(4,418 Views)
About the wiring: I would take the counter input of your device. this makes the programming much easier.
About the programming: you'll find the vi's in "daq acquisition" -> "counter".
(4,418 Views)
I've found the vi's I believe. I don't really understand how to use the counter input. I am using a PCI-6024E. My flow meters have two prongs with no polarity and do not require power. I would put one wire from the flow meter in the counter, correct? But where does the other go? Do I have to use a gate? Thanks for the help.
(4,418 Views)
"moebeth" wrote in message
news:50650000000500000006DD0100-1079395200000@exchange.ni.com...
Software guys may frown but you may wish to use an LM2907 or LM2917 F to V
(from the OTHER National) to convert your mag pickup signal from the
flowmeter to an analog voltage first...
(4,418 Views)
Dear moebeth,
To address your question, can you include more information about the flow meters? As far as I know, turbine flow meters can have outputs of analog voltage, analog current, frequency/pulse, or switch.
If the meters are outputting a voltage, then connect it as an analog voltage input and use the analog voltage virtual channel.
If the meters are outputting a frequency or pulse, connect it as a counter input. With the counter input, you would need to program in LabVIEW without using a virtual channel. Instead, you would use the counter VIs. There are shipping examples included with LabVIEW. Measure Frequency (DAQ-STC).vi can be used just by pressing Run if you wire the signal into the source of whichever counter you want to use and th
e ground into DGND.
Let me know if you have any further questions or if this does not resolve your issue.
Thanks again and have a great day!
Chad AE
Applications Engineer - National Instruments
(4,418 Views)
I think I figured it out. My flowmeters output a frequency. I can't find a counter input on my DAQ board, but I wired my flowmeters into the analog input. Then I used Extract Single Tone to get the frequency. The reading I get in Labview matches with the mechanical flowmeter I plumbed into my system.
Thanks for your help.
(4,418 Views)
On DAQ6024E the counter input is called GPRCTR0_SOURCE on PIN #42 and #37.
Refer to your handbook p 4-30 and ff for the function description.
(4,418 Views)
