Dear moebeth,
To address your question, can you include more information about the flow meters? As far as I know, turbine flow meters can have outputs of analog voltage, analog current, frequency/pulse, or switch.
If the meters are outputting a voltage, then connect it as an analog voltage input and use the analog voltage virtual channel.
If the meters are outputting a frequency or pulse, connect it as a counter input. With the counter input, you would need to program in LabVIEW without using a virtual channel. Instead, you would use the counter VIs. There are shipping examples included with LabVIEW. Measure Frequency (DAQ-STC).vi can be used just by pressing Run if you wire the signal into the source of whichever counter you want to use and th
e ground into DGND.
Let me know if you have any further questions or if this does not resolve your issue.
Thanks again and have a great day!
Chad AE
Applications Engineer - National Instruments
