How can I find the maxima and minima of a signal using labview? I want to draw a upper and lower envelop.
Dear All,
Victor
Message 1 of 9
(5,765 Views)
You can use Array Max & Min VI to find the max/min value for an array
Andy Chang
Message 2 of 9
(5,759 Views)
Thanks. But where can I find this VI? I want to find the local maximum and minimum. Then I want to draw the envelop.
Victor
Message 3 of 9
(5,753 Views)
You mean like a modulation? Are you part of the same group that seems to be asking all about modulation this week? Like this one, this one, and this one.
Message 4 of 9
(5,741 Views)
No. I just want to draw the upper envelop and lower envelop.
Message 5 of 9
(5,715 Views)
I'm not sure exactly what you are looking for. Do you need help in how to use the Limit Testing function on the Signal Processing>Waveform Measurement>Waveform Monitoring palette? The Mask & Limit Testing Express VI can also be used. That allows you to draw the limits on a graph. What is the type of signal?
Message 6 of 9
(5,705 Views)
This is my signal. I want to find out all the local maximum and minimum point then draw the envelop. Which function in the labview should I use? Thanks.
Victor
Message 8 of 9
(5,682 Views)
I would search the array to find the MAX and Min values and draw them as constant lines then. You can use the function “Array MIN & MAX” to do that.
Message 9 of 9
(5,635 Views)
