atmega328p progamming
Hi..
is it possible to programm the mentioned mcu using labview or not?? i have the AVR but i only would like to know wether it is possible to get rid of it or not??... target is optimizing the time needed for such process to be done + having less equipments next to my testing env.
best regards 🙂
(3,835 Views)
if it would not be possible to have it programmed by labview .. how to interface the AVR with labview? cause i already tried and it worked but that was by attaching an exe file which calls the jaitagice.exe
(3,818 Views)
it is possible are you using the arduino board as well? because if you search arduino in the search box you will find a couple of examples
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,814 Views)
actually am using something else, its a module which has the atmega328p as a mcu and a some other atmel chip which plays the trancseiver role.
(3,803 Views)
