How can I format a large number to have comma separators?
Mikael,
Two problems:
Results are unexpected ...
  • If there are more than 2 decimal digits
    (e.g. 8000000000.00 turns into 8,000,000,000.,000 with three decimal digits)
  • If the number is negative and the number of integer digits is divisible by 3:
    (e.g. -800000000.00 turns into -,800,000,000.00).
    It is also probably not a good idea to set "use system decimal point to true". In Europe you'll get a decimal comma which is indistinguishable from the thousands separator. Setting this to FALSE ensures that we get a decimal point.
    I tend to do these operations on U8 arrays instead of strings. One possible solution is attached (LabVIEW 7.0). (It passes the above tests, but there is no guarantee that it is perfect 😉 There are many ways to do this.)
  • 0 Kudos
    Message 11 of 30
    (6,737 Views)
    Hey guys, interesting discussion, here's my own two cents, i think it works for all situations. Let me know!
    Liam
    Message 12 of 30
    (6,490 Views)
    Liam
    Despite 9 years passing and many requests to NI to build comma separation into indicators themselves (such as this), your solution remains the best way to do it.  Nice job making it so streamlined.
    I have one question.  Can you explain what the purpose of this part of the pattern is?  I cannot find any clues in labview's help.
    [~\2E\2C]
    I replaced it wth this and it still works, as far as I can tell.
    Mike
    Message 13 of 30
    (5,516 Views)
    MarredCheese wrote:
    [~\2E\2C]
    2E is the period and 2C is the comma.  These might be special characters for regular expressions, therefore you will need to go by their hex value.  The comma is often used as the decimal separator instead of the period in some countries (like Germany).
    Message 14 of 30
    (5,498 Views)
    @crossrulz wrote:
    MarredCheese wrote:
    [~\2E\2C]
    Oh, ok.  Thanks!
    I attached a minorly updated version.  I changed that part of the string to [~,.] since it's more readable.  I also made it neater, gave it an icon, made precision into an input, and wired up the connector pane so it can be used as a subVI.
    Message 15 of 30
    (5,450 Views)
    Very interesting posting.
    Can somebody convert the last example for LV2012?
    Message 16 of 30
    (5,367 Views)
    Isn't there a Number to string format (%9.3f) style of conversion?  Your VI inserts a comma every 3 digits, but it is also putting a comma at the beginning, Example:
    186282.396 = ,186,282.396
    Message 18 of 30
    (4,778 Views)
    That VI is much better, however it keeps trimming the decimal numbers to 2 digits, How do I control that.  You also know that it is also proper to group digits in 3 digit groups with comma's as well.  So if I have a long decimal number like 3.1415926 it should read 3.141,592,6
    Message 19 of 30
    (4,777 Views)
    Which VI's are you referring to in your last 2 messages?  When you reply to an older message you should add that message using the quote button so we know what you are talking about.
    But JB's VI in message 17 seems to work properly.
    And no it is not proper to put commas in the decimal portion of the number.  That is something I've never seen before.
    But I did come across another idea in the Idea Exchange, a duplicate of the one I posted on your other thread, where Henrik Volkers posted a VI that did to a separator in the decimal portion.  He defaulted his to a space rather than a comma.  But that is easy to change and seemd to work.
    https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Format-into-string-with-thousands-separator/idi-p/112...
    Message 20 of 30
    (4,771 Views)
