How can I format a large number to have comma separators?
it's 2019
Screens and graphics allow a more easy way (better readability) to display long numbers (on each side of the decimal seperator).
Numeric inputs and outputs of a modern UI should be able to group the numbers with fractions of a space (I would prefer as a general seperator).
And don't miss the scales !!
Ideas to push:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Visual-Aides-Numeric-Separators/idc-p/3881749
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Digit-grouping-for-Numerics/idc-p/2123338
Greetings from Germany
Henrik
LV since v3.1
Message 21 of 30
(4,578 Views)
There's some good function in .net for this that I made a test with. I can't find it quickly though.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 22 of 30
(4,572 Views)
Well. since 20 years I can use TeX to set nice tables for documents ... however, I want this in native LabVIEW on my UI including the graph scales.
Henrik
LV since v3.1
Message 23 of 30
(4,561 Views)
@Henrik_Volkers wrote:
it's 2019
"long numbers" (especially with a reasonably number of significant digits), should probably be displayed in SI or scientific format anyway. Much more concise.
Even with seperators, things will get out of hand if you need to (mis?)count the number of triplets, for example. The problem is just pushed a little bit, but still exists.
Message 24 of 30
(4,552 Views)
There's a good .net function for that, that I finally figured out (though I agree with Altenbach about the SI format).
/Y
Qestit Systems
Message 25 of 30
(4,533 Views)
That is why my go to formats for numbers is "%0.3p" and "%#.3p" (depending on if I really want to see the trailing 0s or not).
Message 26 of 30
(4,521 Views)
Unless you have to deal with ppms and ppbs 😉
Henrik
LV since v3.1
Message 27 of 30
(4,510 Views)
That would be an exception.  99.5% of the time, 3 decimal places is more than enough.
Message 28 of 30
(4,504 Views)
Say for 99,5% of the applications ...
unless you work in a national metrology lab... 😄
Henrik
LV since v3.1
Message 29 of 30
(4,497 Views)
There was a small bug with code posted above. You to exclude a comma when the "substring after match" output = "" (null string) otherwise it adds an extra comma at the beginning of the number.
Message 30 of 30
(2,623 Views)
