How can I generate a QR code in labview
Hi
I need an LV application to generate graphics of QR based on an input text.
Do you have any sample code to do it
Message 1 of 10
(14,925 Views)
Thank you for that sample code.
Regards
Message 3 of 10
(14,878 Views)
Here is some ancient code I wrote since I prefer G to C.
Message 4 of 10
(14,876 Views)
Both,
Darin's QR Generator.llb ‏453 KB
and
ongeelim's QR Code Generator 2012 NIVerified.llb ‏576 KB
are well written, plain LabView QR-Code generators.
Darin's Blockdiagram is easier to understand,
while ongeelim's version has more features "out of the box":
Message 5 of 10
(14,782 Views)
Hi alexderjuengere
I use both QR generators but they cannot read in LabVIEW. I attached the reader vis they give me Error.jpg error. The error title "Error -1074395318 occurred at IMAQ Overlay Lines".When I generate QR code from an online generator reader vis are work. When I use a cell phone QR reader application, the application reads all of them.
How can I fix it? can you help me?
Sorry for my English.
Message 6 of 10
(13,735 Views)
I found out the right setting for the generator. I am sharing the generator and the reader is working for me.
I think my fault is data mode I chose alphanumeric in generation vi. When I chose Data mode Binary, reader vi started work.
Message 7 of 10
(13,698 Views)
thank you all for this amazing Code Generator.
I need to write a multi line string to be converted to a QR Code.
If I use this example, all of my line feeds are deleted and the strings are connected in one line.
Is there a chance to get these line feeds into the generated QR code?
Message 8 of 10
(6,533 Views)
In "EncodeStrings.vi", I see this:
Is that "1" constant supposed to be wired to something?
Message 9 of 10
(6,472 Views)
I've done some updating/cleanup.
Message 10 of 10
(6,443 Views)
