How can I generate a pulse train from shaft encoder?
Hey Jango,
From the code you posted it looks like you're trying to use the Z pulse to set the intervals for some type of analog voltage measurement? Are you trying to use the LED to indicate when the encoder has completed a full revolution?
Are you trying to read the appropriate PFI line in the Digital I/O tab? How fast is the encoder turning and what is your sample rate set to?
Andy C.
Applications Engineering
Message 11 of 14
(915 Views)
http://forums.ni.com/t5/Multifunction-DAQ/Beginner-question/m-p/2415124#M76663
I am trying to read the Digital I/O in 1(A) 2(Z) and 3(B) (As mentioned to me in the post).
This is my previous post, I have changed the code, such that Z triggers the sensor on ai0.
My priority is to achive an LED pulse for every Z pulse recieved (that is one full rotation) I plan to align this LED with the Top Centre of my shaft, so that I can measure the Encoder readings from the Top centre. I hope this makes sense.
*I am trying to miss every second z pulse. that is 1 pulse per 2 rev (2048 samples per channel inside the while loop, though I am not sure if this does what I am trying to do.). But this is of low priority.
Message 12 of 14
(897 Views)
Can anyone help me out here?
Message 13 of 14
(877 Views)
Hey Jango,
Since this post was originally devoted to another user's issue, I would ask that you begin a new post with a new problem summary along with a copy of your most recent code. We'll be happy to offer more advice on a fresh thread.
Thanks!
Andy C.
Message 14 of 14
(859 Views)
