How can I generate multiple unique random numbers?
I am trying to generate multiple random numbers between a given set of numbers (1-52) and not have the same number generated twice within that set. I can compare the last and next numbers with the compare function but how would I go about comparing all of the generated numbers without using a huge list of shift registers...
Any help/ideas are welcome and appreciated.
Jason
(9,001 Views)
Hi JasonPKelly,
    I had attached a vi which will generate a random value between the limits i.e between any numbers.
Thanks and regards,
srikrishnaNF
Srikrishna
(9,000 Views)
Thank You, I was unclear. I can generate the numbers within the set I need. My problem was that I didnt want the same number ever generated again within that set. One idea I had was to build an array each time a random number is generated using the same shift register to pass the number each time and then search the array with the new number. Im going to write that and see if that fixes my problem.
jason
(8,996 Views)
Accepted by JasonPKelly
Solved my own problem. Im passing the random number through a shift register each case and building an array each time. I then search the array for the new random number. If the number is not found I get a value of -1, anything else is an index value of 0-whatever. So a greater than (-1) comparer will indicate that the same number is within the array and I can then re-run that case until the same number is not found.
Jason
(8,982 Views)
You can use mathscript for a very straightfoward approach
(8,968 Views)
Here is an implementation of Jason's solution.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(8,957 Views)
