How can I get a waveform in the program?
Hi everybody
I need some help I have a program that motor controller and I need to add a chart for the circuit and I needed to work as:
When the motor is clockwise give 1, counterclockwise give -1
When the motor is half mode give 0.5, full mode gives 1
This is the equation (the number above is used in the equation)
Step0=step value + (step v*cw/ccw*half/full)
Step1=step0 + (step0*cw/ccw*half/full)
Not: the step value given by user, and each click on the clock give us different point on the graph
lordfreddy@msn.com
for contact
(2,548 Views)
i forget to tell you i hav the old Version 6.1 of labview
(2,545 Views)
