How can I get number of samples from lvm file?
Hi, I have attached a lvm file, but i cannot extract the number of samples from the file. How can i do? Thank you!
(2,201 Views)
Here' s the file
(2,198 Views)
Hi tj,
@tj1995 wrote:
Here' s the file
That is what you can read in your txt file:
Channels	8
Samples	5	5	5	5	5	5	5	5
Is this what you are looking for?
(2,195 Views)
Hi, I want to get this property on my labview code. Is there a possibility?
(2,189 Views)
Accepted by tj1995
Hi tj,
Yes, sure!
Read the measurement file and check the number of samples in the waveforms!
Spoiler
(2,185 Views)
Thank you !
(2,171 Views)
