How can I get smooth Envelope waves..? Plz help me.
Hello, everyone.
I wanna get above red waves that is the Evnvelope wave of some input signals.
But I don't know what it can.
Now, I am using DAQ(NI USB-6259BNC ) and Labview 2010 evaluate ver.
Exactly I am wondering that getting above red envelope is possible smoothly.
Now, I can be getting the difference frequency waveform. And I am trying to get a Envelope waveform Using Fast Hilbert transform Block but It isn't working..
I will attach soem pictures those I want to get and VI file. Plz help me.
Have a nice day.
(4,791 Views)
(4,789 Views)
Two things:
1. Multiply your sine signal (with different frequencies), not subtract. That will produce a non-constant envelope.
2. Use Re/Im to Complex, not Polar to Complex.
Lynn
(4,755 Views)
Some additional discussion there. Since the question is not DAQ-related, let's keep the discussion here.
Lynn
(4,750 Views)
Oh.. Thank you for reply.
Could I get your VI file?
Have a nice weekend
(4,737 Views)
I couldn't understand those pictures without VI file, sorry..
(4,736 Views)
I used the Diagram Disable structure to disable the DAQ VIs so that I could test the mathematics. If you wnat to run with your hardware, you will need to remove the Diagram Disable structures.
I also have some extra code to verify that Absolute Value correctly calculates with complex inputs. That is how I discovered that you had the wrong conversion to  complex. I changed some captions to make identification of graphs readable in English.
Lynn
(4,719 Views)
