How can I get the row number of display automatically on a table?
I have a table of measurements, and I would like the row number to be displayed on each row. The challenge is that each time I run the program, the total number of rows will be different, so I would like the numbers to update every time I run the program based on the current number of rows.
I have attached a picture to illustrate what I am trying to do.
(4,569 Views)
Create a Property Node for the Table Indicator and select the RowHdrs[] and ColHdrs[] properties. You can wire an array of strings to each of these to give the headers whatever info you'd like. I've built a simple VI that builds a 2D aray of strings of random sizes, then builds arrays of strings for the column and row headers.
CLA
(4,557 Views)
Accepted by topic author Laura121
Find the attached example (saved in version 2009), and you can extract what you need for your code...!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,552 Views)
