How can I resolve this error IMAQ?
Please give me information about this type of error.
Message 1 of 13
(4,022 Views)
What error are you talking about?
Message 2 of 13
(4,008 Views)
Where is the error...???
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 3 of 13
(4,007 Views)
when I want to start program comming this error and shows that IMAQ Write JPEG File 2 Is wrong
Message 4 of 13
(3,995 Views)
Have you tried wiring an indicator to 'Image Out' output of 'Kamerainställningar gigE_2(SubVI).vi' and check, if actually there is an image available at this output??
Message 5 of 13
(3,989 Views)
No. How can I do that?
Message 6 of 13
(3,978 Views)
You can find the same from 'Controls Palette' as shown below:
And on the 'Block Diagram', you'll see a terminal corresponding to this indicator. very similar to below picture... and that you need to connect to the wire.
Message 7 of 13
(3,975 Views)
I tried to delete it and fix another thing to save pictures! can you suggest another way to save pictures?
Message 8 of 13
(3,974 Views)
Actually i did it but I must find a way to save pictures JPEG
Message 9 of 13
(3,967 Views)
To save a picture, you must be sure that, there is a picture available...!!
Try the attached code, and you'll see that 'IMAQ Write File 2' works beautifully, without any flaw..!!
So I suspect, the error you're experiencing is because there is no image available.. or also may be because there is an incompatible image that you're trying to input to 'IMAQ Write File 2'..!!
Message 10 of 13
(3,960 Views)
