How can I integrate with the limits I want?
Hi people again,
I need to integrate between to limits 37 and 77 you can see in the graph image that I add,
now the integration that I do is all the graph and I want this values like a control.
is it posible to do?
thanks.
Message 1 of 19
(3,953 Views)
First you need to find out what array indexes relate to the x-axis values of 37 and 77 and only send that subset of the entire array to the integration. The Threshold function can be useful for that.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 19
(3,940 Views)
I have not gone myself, but probably same stuff was discussed in this post.
The above post talks about 'Area under Curve'.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 3 of 19
(3,938 Views)
I now what you say but... the threshold function give me an error :S
help please
thanks
Message 4 of 19
(3,934 Views)
The output of the threshold function is a fractional index. Round it to the nearest integer an us it to calculate the subset of elements you need. There is an array subset function that can actually extract the data for you from the arrays.
Mike...
LabVIEW Champion
Message 5 of 19
(3,929 Views)
I don't understand you maybe i pass  my VI I think you say something like I did....
Message 6 of 19
(3,921 Views)
Please help mike Smiley Frustrated
Message 7 of 19
(3,910 Views)
Try something like this...
Mike...
LabVIEW Champion
Message 8 of 19
(3,871 Views)
Can you save with version 11?
thanks
Message 9 of 19
(3,867 Views)
try something like this.
Mike...
LabVIEW Champion
Message 10 of 19
(3,862 Views)
