How can I interactively create a New File in LabVIEW 2011?
I am trying to create a new binary file interactively in LabVIEW, but the File Path control only offers the ability to either type in the full path and file name (cumbersome for the user), or browse for an existing file. I want to open a "New File" dialog that will allow the user to browse to the target directory, then be able to enter the name of a non-existing file to save the data to.
The way I'm currently doing it is creating a TXT file using the Windows Explorer "New Text Document" pop-up, then changing the file extension to the new value...which is again, very cumbersome.
The only thing I've found online is that there used to be a "New File.VI" in an older version of LabVIEW apparently...but I can't seem to find it in 2011.
(2,681 Views)
Accepted by Ryan_G_EE
You can create a new file using the browse button.
Did your right click on the file path control and check the settings in the "Browse Options" menu?
(2,679 Views)
LOL. Hadn't tried that yet. Now have it working, thanks!
(2,664 Views)
