How can I keep the front panel look like exact the same on different computer screen with different size and different resolution?
(3,302 Views)
Hi
Goto File>VI Properties>select "windows size" as category>select the option "maintain proportions of window for different monitor resolutions"
Luca P.
Application Engineer
Luca
(3,302 Views)
This solution works only for graphical objects (graphs, pics...), but not for additional text or button text.
How can i modify all the polices to keep the same panel proportions for all screen resolution ??
(3,302 Views)
Under the VI properties there's a tab for window size. Set this to be fixed at the smallest resolution that your program will encounter and it will always look the same.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,302 Views)
Ok, that's a solution...but a 800x600 fixed screen size looks very small in a 1280x1024 or higher...
There is really no solution to manage police size for multiple screen resolutions ???
Matt
(3,302 Views)
Not other than the automatic rescaling operations available under VI properties, that other posters already told you about.
You could resize and reposition things manually using property nodes, but that would be a pain if your screens were even slightly busy...
Mike...
LabVIEW Champion
(3,302 Views)
