Selecting one of VI windows from the bottom of WinXP didn't bring up the VI
I opened several VI windowss and other application softwares. After switching to another windows (not Labview) and back, I found that I couldn't open the VIs. They were listed in the bottom bar of WinXP. However, when I chose one of them, the VI window didn't show up. If I right-clcik a VI and chose "Maximu", the VI showed up but cannot be resized. That's really strange. How to solve this problem? Thanks.
(3,008 Views)
LabView opens windows for a VI's front panel and diagram in the locations at which they were last saved. It sounds like the VI you're having trouble with was saved to a location off the screen, maybe on another computer with a different screen resolution.
When you maximize a window, it's displayed to fill the visible screen, regardless of the original window position. For any Windows window, you can't resize the window when it's maximized. You have to Restore it before you can resize it. But for you, the restore puts it back off the screen where you can't see it.
Normally, in Windows, you move a window by grabbing its title bar with the move and dragging it around. If you can't see the window, you can't use the mouse to move it. But you can use the cursor arrow
keys to move it.
1. Left-click on the task bar button for the VI so it's depressed. Left-click on the task bar is a toggle button: click once and the window is displayed; click again and it's minimized. The task bar button will be depressed when the window is displayed and raised when it's minimized.
2. Right-click on the task bar button for the VI and select Move.
3. Press and hold each of the cursor arrow keys, one at a time, and watch for an empty rectangle to move across the screen. If you don't see a rectangle after holding one cursor key for about 5 seconds, try another key.
4. When you see a rectangle on the screen, press Enter and the window will be displayed.
5. Save the VI with the windows in the desired position.
(3,008 Views)
That's a known problem. I had same experience. And I saw similar posts.
You can download "Find Missing Window" on my web site.
George Zou
http://gtoolbox.yeah.ent
George Zou
(3,008 Views)
yes I have experienced the same thing with XP. George has mixed up his link - it's http://gtoolbox.yeah.net...
George - the link says 6.1 only. This happens for me in 6.0.2 - do you have a version for this?
Thanks, Paul.S
(3,008 Views)
I tried to search for the answer in the forum but didn't find them. Thank you very much for your help.
(3,008 Views)
Thank you very much. I will try when encoutering the problem again (not always happened). I just feel strange since other softwares don't have a similar problem like this.
(3,008 Views)
Yes. It's attached. I didn't know it's happening to 6.0.2 either. This VI is useful only when you have an unsaved VI missing. Otherwise, you can simply quit LabVIEW, and open the VI again.
I suspect that LabVIEW mistakenly treats the VI as one of its hidden windows.
George
George Zou
(3,008 Views)
