Why can't I see the data in the spreadsheet ?
why can't I see the data in the spreadsheet file in Which I wrote my output data? I set the format of write to spreadsheet file to be %.11f. Though I can see only colums of zeros, I can plot out the data.
(2,686 Views)
I tried th "%.11f" format and it worked in the attached VI (6.1). Please respond and attach a small example VI that demonstrates your problem.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,686 Views)
The %.11f will truncate your number to 11 decimal places, not to be confused with 11 significant decimal places. If you are generating very small numbers and your plot is on a logarithmic scale, it might be that your numbers are simply too small (<10^-11) to be saved properly, even though the plot looks good.
Otherwise it sounds like a bug.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,686 Views)
THANKS, I HAVE FINALY SOLVED THE PROBLEM
(2,686 Views)
THANK YOU SHONEILL!
(2,686 Views)
