has anyone made any work for CiA Draft standard proposal 406 for Encoders?
We are asked to program a test application for encoders. The encoders have a varity of interfaces. One of them is CAN which uses the CiA Draft standard proposal 406 for Encoders.
Has anyone made VIs for this standard?
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,494 Views)
This seems like a application layer protocol. Is that right?.
If so, NI doesn't have VIs to decode this particular protocol. At the moment the NI-CAN driver provides the Frame API or the Channel API.
Let's see if someone else has worked with this protocol.
DiegoF
(2,494 Views)
