Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I list more than 100 VI's during Object find?
RicK.
Member
06-25-2003
09:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am trying to use the LabVIEW 6 Find tool. When I select Object and VI it only lists 100 subvi's within the application. Is there a way to increase the number of subvi's listed?
LabVIEW_Find_example.bmp 974 KB
0
Kudos
Message
1
of 3
(2,622 Views)
Reply
Re: How can I list more than 100 VI's during Object find?
Photon_Dan
Active Participant
06-25-2003
09:47 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Use the "VIs by Name" option. I'm not sure what the limit is on that one, but it should be higher than 100.
Remember that Alliance Members are here to help. We do this stuff every day.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
1
Kudo
Message
2
of 3
(2,622 Views)
Reply
RicK.
Member
Author
06-25-2003
10:03 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
That solved my issue. Thanks for the tip!
0
Kudos
Message
3
of 3
(2,622 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
