How can I make a graph plotting 2 channels of DAQmx device?
Hello all,
I'm using a USB-9215A to capture three channels of analog data. I am using SetUpChannels.vi to scale each of the three channels then DAQmx Read in a while loop to continually read the data. I split the combined signal into three signal. This is where things go wrong...I use a Build XY Graph poly using two of the signals (my x and y axis) then run the XYGraph output to an XYGraph. Is there anyway to get the graph to keep the old data and just put the newest in to update the graph? I eventually want to send this array out to a csv or similar file but i cant even get it to hold the old data from the last pass through the while loop 😞    This is a low speed application (around 10hz) so a speed hit wouldn't be a factor at all..
Any help would be GREATLY appreciated.
Dave Long
oh BTW i am using LabVIEW 8.20 and would gladly post my project if anyone wants to see it.
(2,863 Views)
The easiest for you would be to just use the Express XY Graph. There's an input called Reset. Just wire a False constant to it.
(2,859 Views)
Thanks Dennis,
I was going crazy trying to concatonate and put in loops with feedback. Whew, one lil T constant did it all. Thanks so much!
Dave
(2,853 Views)
