I created a quick sample based on one of the shipped samples.
See the attached screen shot. The trick with the stereo channel is to select the properties option on the Convert To Dynamic Data if you enter it youself. Then set it to handle a 2d array.
You could readily FFT this data either from the microphone or the wav file. Check out the shipped examples using the keyword FFT.
This example was tested using the Chimes.WAV sample found in the C:\windows\media folder. I will post the properties window for the Align and Re-sampling Express VI as well.
Hope this is what you needed.
Message Edited by Conseils on
11-07-2007 09:59 PMMessage Edited by Conseils on
11-07-2007 10:00 PM
