How can I make difference frequency on NI USB-6259?
I wanna get difference frequency between 100kHz sine wave and 90kHz sine wave.(=10kHz)
For getting that difference frequency, I think I have to make different two sine waves. But I can't it..
But I encounterred some error masages.. If I can get the difference frequency, I hope to send any analog output.
I will attach my project. plz find the errors if you can..
plz help me TT
(3,327 Views)
Do you need to behave like a frequency sweep?  If so you won't be able to do it with a Analog Output, instead you'll want a counter.  If you just want some way to change the frequency at from a UI control that can be done no problem.  What have you tried so far?  Post code you have done in an attempt to make it work.
(3,321 Views)
thank you for reply.
plz see under picture. I wanna get green wave.
(3,308 Views)
dd
(3,307 Views)
ff
(3,301 Views)
