How to create a determinant VI?
I would like to create a program to calculate 3x3 matrix determinant. I know labview provided this function but i want to build myself. Any idea?
Message 1 of 8
(7,488 Views)
Maybe this will help you:
Remember!!: this is only true with matrices from 3x3.
You could use "get matrix diagonal" and "get matrix elements"
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 2 of 8
(7,475 Views)
How about an array and a FOR-Loop? Here's a brute-force attempt:
Alex
Message 3 of 8
(7,451 Views)
Look at the Wikipedia article on determinants. In the Calculation section you will find discussion of alternate methods which are considerably more efficient for large matrices.  For your 3x3 matrix that is not an issue, but if you are interested in numerical calculation techniques, you should study those other methods. Very often using the definition of a mathematical process is far from the best way to calculate the result numerically on a computer.
Lynn
Message 4 of 8
(7,442 Views)
The Numerical Recipes books offer code snippets and algorithms designed for efficient computer use.  You will need to translate from C/Fortran to LabVIEW, but that is usually fairly straightforward.  The "obsolete" versions are online with full text.
Message 5 of 8
(7,410 Views)
There's a built-in Determinant function.
Functions -> Mathematics -> Linear Algebra -> Determinant
Message 6 of 8
(7,380 Views)
Message 7 of 8
(7,360 Views)
I noticed that after I clicked "Post".
Sorry for the wasted electrons (at least they were recycled).
Message 8 of 8
(7,347 Views)
