How can I normalise range on x-axis on graph to 0-100% cycle time?
Hi everyone,
I have small problem hopefully someone can help with me... I have a number of 1D files with data sampled at the same rate (0.067Hz or 1 sample every 15 s); but the files lengths are different due to longer/shorter recordings (range of 188 to 233 data points in each file)...
How can I normalise these files so the x-axis is in units of % duration (i.e. 0-100%).. I assume I will need to interpolate each file by a different factor to provide a common file size (e.g 300 data points); then resample down by a factor of 3 (or the like)..?
Having troubling doing this... Nothing seems to work?
Any suggestions appreciated.
Thanks.
Jack
Message 1 of 9
(5,857 Views)
Hi Jack,
different approaches:
- use a XY graph. Scale the x values (your "duration") for each file/plot, to fit your 0…100% range…
- use a waveform graph. Put your files/plots in waveforms and change the dt of the waveform to fit your x axis range…
- interpolation/resampling might be a solution too…
Message 2 of 9
(5,854 Views)
Hi GerdW,
Thanks reply... One file for example has 3120 data points sampled at 0.067Hz (15 s samples)... While another file has 2870 data points.
Would it be possible to provide me with an example of one of those methods??... I tried all these and could not get any to work.. Mainly focused on the interpolate and resample approach.
Thanks.
Message 3 of 9
(5,831 Views)
Accepted by jcannon
Hi J,
like this:
Both graphs will show both plots over the x range of 0…1!
Message 4 of 9
(5,814 Views)
Thanks G..
Do I need the for loops with the auto index, or can I input data direct from "Read from spreadsheet.vi"? I assume the for loops are just to provide a dummy data session.
Also, I assume no prob with changing 0-1 range to 0-100?
Thanks again... Will try this later tonight...
Jack
Message 5 of 9
(5,804 Views)
Hi Jim,
your assumptions or ok… 🙂
Message 6 of 9
(5,793 Views)
Hi GerdW,
I went with the build waveform graph option using the reciprocol of the array size... All working... Many thanks for your help!
Jack
Message 7 of 9
(5,658 Views)
Hi GerdW,
Ok... Looks like I may have jumped the gun here... I actually need to save the data to file with an array lenght of 100 data points... So although the methods above will graph the data set with a common x axis range of 0 to 1 units, the number of data points in the signal is unchanged (data set lengths range from 180-400 data points).
How can I down sample (or nomalise)  signals back to a common length of 100 data points?
Any suggestions would be very much appreciated... As always, I will post my working code when the problem is solved.
Jack
Message 8 of 9
(5,632 Views)
Alright... So the Resample and Align express vi was more simple that I thought.... Wire in your signal and wire in the desired dt and you are good to go (where dt is the raw signal length divided by the desired resampled signal length)...
Message 9 of 9
(5,591 Views)
