How can I plot data from excel in a XY graph
hi JelleBenoot,
                                           What file i am attaching, in this just give the path of an excel file with maximum number of row & col, than later select the datatype of columns. you will get the data in 2D array.
Let me know if you got any problem.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 26
(2,894 Views)
Any news?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 12 of 26
(2,863 Views)
could you please can pu vi code of this picture.
Message 13 of 26
(2,832 Views)
could you kindly send me the png file of getting the data from excel to XY Graph
Message 14 of 26
(2,748 Views)
Hello Susheel,
Why do you require the png?
The actual code is posted just above here.
Kind Regards,
Message 15 of 26
(2,741 Views)
Hii Thierry ,
I would like to plot the XY graph  (2 vertical axes with pressure and temp and 1 horizontal axis time),in parallel the values are generated in excel sheet with 3 columns and with multiple rows.
Hence,How can i import the excel sheet columns and rows and plot the generated excel sheet values in XY graph of LabVIEW
Could you please suggest me .
Thanking you,
With best regards,
Susheel
Message 16 of 26
(2,719 Views)
Hello Susheel,
Thank you for your reply!
Can you share what you have already tried/made based on the llb above?
I don't mind debugging your code, but I want to avoid that i am writing code for you without you first giving it  a try.
I would prefer to teach you something by using LabVIEW instead of just giving you the solution right away.
Keep in mind the following saying:
Give a man a fish, and you feed him for a day; show him how to catch fish, and you feed him for a lifetime.
Kind Regards,
Message 17 of 26
(2,712 Views)
Hey Thierry,
I have attached the sample work for your ready reference and the ideas of implementation.
Could you make the necessary suggestions further.
Thanking You,
With Regards,
Susheel
Message 18 of 26
(2,677 Views)
Hello Susheel,
Can you please post the VI?
This way I can modify your VI and verify if my suggestions work.
Kind Regards,
Message 19 of 26
(2,670 Views)
Hii Thierry,
I would like to attach it when i sent the picture format .but it has the problem as listed down in the attachment
Susheel
Message 20 of 26
(2,665 Views)
