How can I plot data from excel in a XY graph
Message 21 of 26
(1,757 Views)
Hello Susheel,
What is the sample excel file you are using?
In your code I see nothing from the library above.
Have you tried anything using the VIs from that library?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 22 of 26
(1,743 Views)
For example,  i would like to plot the graph w.r.t the excel sheet attached.Now comes the question of importing the excel data as shown in the example and plotting the same on XY graph using time w.r.t temp.RH.
Needs your valuable suggestion.
With Regards,
Susheel
Message 23 of 26
(1,738 Views)
Pl post its 2012 conversion
Ajay Shankar
Message 24 of 26
(1,323 Views)
Please, where i can find this conversion?
Message 25 of 26
(1,076 Views)
Hi spaniard,
When you need a (down)converted version of a specific VI you could post in the VersionConversion thread.
Here is a snippet of the last VI attachment in this thread:
Message 26 of 26
(1,072 Views)
