How can I plot multiple curves using the XY graph?
I'd recommend getting to grips with formatting your own data using build cluster and build array. The blue express vi you've used does make life easy to start with but I've never got on well with it when using multiple plots.
The image below is equivalent (it just uses bundle).
If you replace your subvi with this, I think your code will work.
Ian
Message 21 of 33
(10,031 Views)
nop because of the same problem, if i use your code, the graph run the axis values change but no line .... that really really mysterious
Message 22 of 33
(10,026 Views)
Why don't you attach the main and subVI (or a simplified version). It is very difficult to determine data structures by looking at a picture.
How about right-clicking the "built array" node and specifying "concatenate inputs"?
Message 23 of 33
(10,007 Views)
you right ... it was the right answer to right click and concatenat input !!!
i find it in the afternoon !!
thank you very much
and about all my program it is a long one with many sub VI and i am on LV 10
but thank you again 🙂
Message 24 of 33
(10,004 Views)
Hi, is there a possibility to use stacked Plots on a xy-graph? thx
Message 25 of 33
(9,752 Views)
Yes, of course!
Message 26 of 33
(9,747 Views)
ok, could you please write a how to for stacking plots in XY Graphs - i can't find a example of this - maybe i'm blind - ...
(Cluster of XY-Graphs - or is it possible to "squeeze" the plots in one stacked xy-graph?)
Thanks a lot!
Robert
Message 27 of 33
(9,740 Views)
any suggestions here?
Message 28 of 33
(9,718 Views)
I'm interested too.  Any thoughts on this?  The stacked plot button is greyed out for me when i create an array of clustered arrays - although the graphs do come out on the same axis, but i'd prefer stacked plots
Message 29 of 33
(9,559 Views)
Thanks, This method works fine. But how to understand which data set is representing which curve?
Message 30 of 33
(6,003 Views)
