How can I programmatically display a .pdf file from LabVIEW?
I would like to display a .pdf file in a text or picture box.  Can this be accomplished, and how?  Can I call a windows API function?  If so, which one and please give me an example.  Thanks
(4,046 Views)
How about an ActiveX control, take a look these posts:
George Zou
George Zou
(4,037 Views)
You can use Internet Explorer as an ActiveX object, then load local PDF files or retrieve the PDF from a site via http.
 An example is located here:
 http://forums.lavag.org/Embedded-Web-Browser-IE-Only-t5402.html&pid=21578&mode=threaded#entry21578
Message Edited by Phillip Brooks on 08-24-2007 01:39 PM
(4,029 Views)
Thanks for the advice.  I see how to do it now.
(4,021 Views)
