problem with colour used in plot legend
Hi I have problem setting the colour for lines at Plot 0 and 15
Here's attached. I am using LV 7.1 Not sure if it carries bug
regards
Clement
(3,075 Views)
Hi Clement,
Did this occur after you had been using the plot and changing properties programatically?  Do you have ideas on how you arrived at this?  It looks like all the plot properties are set up the same.
Clint M
(3,058 Views)
Hi Yes that's correct. After it was altered programmatically, at the edit time, it seems that I cannot change.
I tried it again in my program and set it right by programmatically. Surprisedly Why is that it cannot be edited in the edit time?
Thanks your reply.
Clement
(3,037 Views)
Hi Clement,
Could you attach your VI so that I can see all of the properties that you are editing programatically?
Clint M
(3,019 Views)
