How can I programmatically set the camera drivers through LabVIEW
What I would like to do is to programatically set the camera drivers for an interface using LabVIEW. I am not getting much luck on trying to drag and drop a non-shipped camera driver into MAX under the NI-IMAQ/Data/ So I would like to programatically set the camera drivers from LabVIEW. How would I do this?
(3,166 Views)
You could find your luck here:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E9DF56A4E034080020E74861&p_node=DZ52489&p_submitted=N&p_rank=&p_answer=&p_source=External
... further tech notes can be found serching the NI website first ...
(3,166 Views)
Micheal,
Thanks for the link, unfortunatly though the example is in 7.0. I only have 6.1. Is there some way to get it in that version?
Brian
(3,166 Views)
Hello Michael,
Here is the example in LabVIEW 6.1.
I hope this helps,
Sean C.
(3,166 Views)
