when I press "install" in the autorun page it doesn't work
When I pressed "install" the CD-ROM had run for several minutes, then the autorun page automatucally closed and nothing happened afterward.
(2,512 Views)
college student,
In this case it would be really helpful to know which operating system you are attempting to install LabVIEW on. Make sure that you are installing your LabVIEW CD on a compatible operating system.
You may also navigate to the setup.exe file on the CD itself. You will want to open a file browser and open the LabVIEW CD within the file browser to find setup.exe. You can also click on �Explore CD� link on the autorun page, navigate to the setup.exe file, and run it.
If you are still having problems please post back with more detail on the system you are attempting to install LabVIEW on (OS, LabVIEW version, etc.) Good luck!
Craig H.
(2,512 Views)
