How can I read and write text in rings that are inside an array?
Hello All!!!
Regards and thanks in advance.
(3,257 Views)
carmo,
When you say 'write' do you mean you want to edit the list of items or choose active item?
(3,247 Views)
Use a Property Node linked to the Ring inside the array.
Of course, all elements in the array will have the same text values.
B-)
Message Edited by LabViewGuruWannabe on 12-13-2007 09:47 AM
Message Edited by LabViewGuruWannabe on 12-13-2007 09:48 AM
Message Edited by LabViewGuruWannabe on 12-13-2007 09:49 AM
(3,242 Views)
Thanks!!!!
(3,236 Views)
HI
could u please explain how to get to the propoerty node ring thingy as I cannot really understand how u transfered the contents of one array to the other one using the property node. Would be much appreciated if u cud post the VI.
regards
daq newb
(2,959 Views)
See the attached pics to get to know how to create a prop node for a Ring inside an Array.
- Partha ( CLD until Oct 2027 🙂 )
(2,950 Views)
Thx heaps for ur prompt,clear and accurate response
Don
(2,946 Views)
