How can I reinitialize a feedback node in a SubVI and in a timed loop
Hi everyone
I have a SubVI counter in a timed loop (LabVIEW FPGA ) , in this SubVI I have a feedback node with some initial value , but when it is called multiple times , I noticed it take the last value in previous execution and not the initial value .
How can I resolve this issue ? the outer timed loop runs infinitely
(1,393 Views)
Right-click on the feedback node and select "Move Initializer One Loop Out".  Wire an initial value to the initializer terminal.
paul_a_cardinale_0-1703765670913.png  paul_a_cardinale_1-1703765724142.png  paul_a_cardinale_2-1703765784061.png
(1,338 Views)
Or just wire the initialiser terminal at the bottom of the Shift Register, same effect.
(1,324 Views)
I tried this , but still it doesn't work and maybe because it is an infinite loop and from host the initial value get called only once .
Still after first call , in the next calls the initial value is previous executed value
Is there a way to solve this issue without shift register or move init out of loop?
(1,308 Views)
Accepted by ehsan11
Hi ehsan11,
By definition, a feedback node gives the value from the previous call.
You can add a mechanism to reset your counter under some condition by doing this:
Or similarly:
Raphaël.
(1,301 Views)
