How can I reset a waveform chart when I switch from one node to another?
How can I reset a waveform chart when I switch from one node to another? Right now when I switch nodes it jumps to the position of the second node and continues on. I would like it to clear out the previous node before It starts plotting the new node.
(2,766 Views)
Create a property node of the chart.  What you are looking for is History Data (should be at the bottom of the select list).  Wire an empty array to this property.
(2,764 Views)
When I did this it constantly resets the waveform chart. What controls when this is executed?
(2,746 Views)
Accepted by grimm1099
It happens whenever that part of your code is ran.  Did you put it inside of a loop?  Did you program specific instances when the chart should be reset?
(2,737 Views)
