How can I reverse a signal from a measurement file (*.lvm)
I have a signal obtained from a NI aquisition device.
The signal length in 131072 samples, and the sampling frequency is 15KHz.
I need to reverse this signal so that sample 1 becomes sample 131072, and sample 131072 becomes sample 1.
In matlab I can do this with the "fliplr" function, but I would like to save the reversed file as a *.lvm file.
Can you help me please?
Thank you and have a nice day.
(2,742 Views)
Hi raul,
there's a "reverse 1d array" functiuon in the array palette. Try this on your sampled data!
(2,741 Views)
Yep, Reverse 1D Array should do the trick, but if you're dealing with LVMs and measurement data initially, you might need to do a little conversion of data first.  This might be closer to what you're looking for.  Good luck!
Message Edited by Jeff B on 03-13-2008 08:56 AM
(2,733 Views)
