How can I run Oracle based stored procedures in LabVIEW using DB Conn. Toolkit?
I need some help on how to run Oracle based stored proceures in LabVIEW using Database Connectivity ToolKit. Examples VIs will be appreciated.
Thanks.
(3,293 Views)
I'm not very familiar with the DB connectivity toolkit. I normally use this toolkit (http://jeffreytravis.com/lost/labsql.html).
You can make any SQL queries from LabVIEW with it.
(3,290 Views)
Use the "DB Tools Create Parameterized Query.vi" to create a SQL command and set the terminal "stored procedures?" to be true. (See attachment example)
About how to use DB Tools Create Parameterized Query.vi, refer to:  \examples\database\Database Insert.vi
Message Edited by Talen on 04-29-2009 03:43 AM
(3,249 Views)
